• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    tmcmannis
    Fatal Error when changing annotation scale for Viewport
    221 Views, 2 Replies
    11-26-2012 09:43 AM
    Hi everyone. I have some files that are difficult to work with. Every time I try to change the annotation scale of an existing viewport or create a new viewport and set the annotation scale equal to something other than the default 1"=40' the file fatal errors on me. Have any of you encountered this problem, and if so how did you resolve it? Thanks for your help.
    Oh, Im on Windows XP 64 (8gb Ram and a Xeon) running C3D 2011 (all service packs and updates applied).
    Thanks!
    Please use plain text.
    Re: Fatal Error when changing annotation scale for Viewport
    11-27-2012 05:41 AM in reply to: tmcmannis
    Some files, not all files?  Sounds like a corruption.
    Purge
    -Purge   Regaps
    Audit
    Recover.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Contributor
    tmcmannis
    11-27-2012 07:23 AM in reply to: troma
    It's actually looking like it might be all the files...have yet to find one that we can modify that doesnt crash. We've tried purging regapps, zero length geometry, and everything else and it still crashes.
    Just for giggles I ran a Map query to redraw one of the sheets and imported the layout from the original drawing and the problem persists... even with a new from scratch viewport. This is the first time I've encountered this issue and its really proving detrimental to our production speed and output. Please keep the suggestions coming. Thanks for your help!
    -Tristan
