• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Failure to access Subscription Center
    217 Views, 3 Replies
    10-19-2012 09:17 AM
    I used to be able to get into the Subscription Center, but no longer can.  I just get a message saying "The Subscription Center cannot be accessed due to a problem with your internet access or an Autodesk server."  Obviously, since I can post here, it's not a problem with my internet access.
    Anyone else seen this?
    I wanted to post another complaint about Cogo Points disappearing as the cursor goes over the Point Label when using the COPY (with Blocks) or POLYLINE or Modify Tab->Insert/Delete PI commands, but cannot, since I can't access the Subscription Center anymore.  It's getting very annoying needing to cancel a command and use REGEN to see the Cogo Points again.  I think this problem started in C3D 2011.
    Sinc
    Please use plain text.
    Valued Mentor
    Re: Failure to access Subscription Center
    10-19-2012 10:20 AM in reply to: Sinc
    Sinc,
    They just shut the server down since the were getting some many complaints about C3D12 service pack blowing things up and the fact that they'll probably need to release C3D13 again, since it still has the same bugs and more. (The good thing about that is the release year with match the true year) :smileylol:
    10-19-2012 12:27 PM in reply to: Sinc
    Richard:
    I jumped right in to the subscription center, no problem.  Perhaps you may need to slip iin under an alias.
    <G>
    Bill
    AllenJessup
    10-22-2012 07:15 AM in reply to: Sinc
    I don't have any problem today [Monday} but I wasn't here on Friday. Has it cleared up for you?
    Allen
