• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    FATAL ERROR Unhandled e0434352h Exception at fda0caedh
    1479 Views, 2 Replies
    11-15-2012 01:12 PM
    Sorry to bother, but I've searched and can not find out what this error is or how to fix it. My ACAD C3D 2011 was working fine yesterday and for the past 4 hours this morning, it opens to command then this error appears closing the program. Behind the error notice the drawing is showing, but of course I can't do anything since the program is shutting down. Not an equipment problem, been running the same computer, drivers and programs since C3D was installed originally.
    Thanks in advance
    Don
    Please use plain text.
    Active Member
    Re: FATAL ERROR Unhandled e0434352h Exception at fda0caedh
    11-15-2012 02:04 PM in reply to: ddouglas
    Never mind ACAD has fixed itself after 5hrs of trying I gave it one more try and it opened with no problem.
    Thanks anyway
    Don
    Valued Mentor
    owenmull
    11-15-2012 02:16 PM in reply to: ddouglas
    http://forums.autodesk.com/t5/AutoCAD-2010/FATAL-ERROR-Unhandled-e06d7363h-Exception-at-7c812afbh/m-...
    Read post # 8.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
