• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    GreeneSWCD
    Extracting Cross Sections help
    102 Views, 3 Replies
    11-28-2012 06:05 AM
    I have an alignment going up the center of a draw.  I'd like to extract cross sections of this alignment and existing ground.  What is a good way to do this?
    I don't do cross sections very often, so when I need one, I draw a second alignment perpendicular to the first and profile that alignment to give me a bare bones cross section.  I'd like to do these cross sections on a given interval, and at every change in direction.  How should I go about it?
    Thanks.
    Please use plain text.
    Valued Contributor
    bo.martin
    Re: Extracting Cross Sections help
    11-28-2012 06:19 AM in reply to: GreeneSWCD
    My method....
    I chose these from the menu bar, So be sure to have it turned on.
    Create a profile 1st.
    Sections>Create Sample Lines
    Sections>Create Section View
    Hopefully you have a Style created.
    Good Luck,
    Bo
    11-28-2012 07:08 AM in reply to: bo.martin
    In the create sample lines command there are options to create by station; where you click the location or type the station, or to create by range; where you set the start point, end point and the interval.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    GreeneSWCD
    11-28-2012 07:11 AM in reply to: troma
    I'm getting there, thanks guys.
