AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Extracting Cross Sections help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have an alignment going up the center of a draw. I'd like to extract cross sections of this alignment and existing ground. What is a good way to do this?
I don't do cross sections very often, so when I need one, I draw a second alignment perpendicular to the first and profile that alignment to give me a bare bones cross section. I'd like to do these cross sections on a given interval, and at every change in direction. How should I go about it?
Thanks.
Re: Extracting Cross Sections help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My method....
I chose these from the menu bar, So be sure to have it turned on.
Create a profile 1st.
Sections>Create Sample Lines
Sections>Create Section View
Hopefully you have a Style created.
Good Luck,
Bo
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In the create sample lines command there are options to create by station; where you click the location or type the station, or to create by range; where you set the start point, end point and the interval.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm getting there, thanks guys.
