• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Extract linework from corridor
    182 Views, 7 Replies
    01-14-2013 01:07 PM
    What's the best workflow to extract the linework from a corridor - I need the linework as 3D polys for export to another modelling system??
    I have tried the extract feature line from corridor but it is incredibly tedious so I have lately done the following
    1 Rebuild Corridors and Save file
    2 Select Corridor, Isolate and Explode twice
    3 Select all the lines and JOIN which then creates 3D polylines
    4 Wblock the 3D polylines
    5. DO NOT RESAVE...!!!
    Is there a better way?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    *Expert Elite*
    Re: Extract linework from corridor
    01-14-2013 01:15 PM in reply to: neilyj
    Yes, but you've already said you can't utilize it :smileysad: Better way
    *Expert Elite*
    neilyj
    01-14-2013 01:46 PM in reply to: neilyj
    I'd love to know why a routine like this Sincpac one isn't available ootb in civil 3d and why Autodesk have made extracting featurelines from the corridor so longwinded.
    looks like I'm sticking with the explode method for the time being
    neilyj
    *Expert Elite*
    sboon
    01-14-2013 04:18 PM in reply to: neilyj
    Export the corridor drawing to ACad.  The exported drawing will have 3d lines in it.  Assuming that you can isolate them using layer control or some other method then it's simple to join them into 3d polylines and erase everything else.
    *Expert Elite*
    neilyj
    01-15-2013 12:42 AM in reply to: sboon
    This is essentially the same as my exploding method but arguably less prone to disaster as the original data is preserved in the event of "a senior moment" and saving the exploded corridor...:smileyhappy:!!!!
    EDIT: Just tried this and the Z coordinate is 0 (when OSNAPZ is either 1 or 0) but it is preserved using the Explode method.
    neilyj
    *Expert Elite*
    neilyj
    01-15-2013 04:50 AM in reply to: neilyj
    Using the _AeccCreatePolylineFromCorridor command it is easy to extract 3D polylines (presumably this is what the Sincpac routine uses?) but as they are all placed on the current Layer it is quite tricky to know what each polyline represents unless the current Layer is changed for each polyline
    neilyj
    *Expert Elite*
    01-15-2013 07:27 AM in reply to: neilyj
    Change to a 3D view before exporting the drawing. You should get 3D elevations.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    *Expert Elite*
    sboon
    01-15-2013 08:10 AM in reply to: mathewk
    I commented on this issue last week in this thread.
    If your export has to be exclusively 3d polylines then you'll want to check after running the join command.  Any of the exported lines that are a single isolated segment will not be joined, and will not convert to polylines.  I find this happens often with short ditch segments where the daylight is flipping between cut and fill.
