AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Extent of rockfall netting
- Highlight
- Email to a Friend
I have a model of a platform at 29.00m cut into rock and need to find areas where the rock cut is 2m or more as this will require netting - any ideas of a quick way to do this??
Extract the 31m contour and see where it runs is the best I've come up with......
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Extent of rockfall netting
- Highlight
- Email to a Friend
Would not a CUT/FILL depth analysis work?
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
- Highlight
- Email to a Friend
The excavation surface vs a 31m plane surface??
- Highlight
- Email to a Friend
I don't understand your scenario. I assumed you have a proposed surface and want to determine where the cuts are >2m vs. the existing. What do you have to work with?
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
Yes I have a proposed surface and I'm only really interested in the portion that is below rockhead and is higher than 2m above the platform level
- Highlight
- Email to a Friend
In the ranges for the depth analysis, only include those values that fall within the desired parameters.
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
neilyj wrote:The excavation surface vs a 31m plane surface??
No. Create a volume surface of your platform and your rock surface. Run an elevation analysis on the volume surface. Anywhere the elevation of the volume surface is greater than 2m is where you will need the protection. You can then stylize the volume surface and to display those areas automatically if the design changes.
- Highlight
- Email to a Friend
I assumed you knew how to create a cut/fill analysis. My apology for not being more explicit.
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
Thanks Brian I'll try that ....
This will identify the locations where the rock netting is required but the next task is to compute the area of the rock face to be netted.
Perhaps draw a boundary around the affected areas, apply as outer boundary and review the 3D area surface properties??
- Highlight
- Email to a Friend
I just checked and I believe in the Legend table for volumes you can add 3d area or 2d area. We use it all the time in the slopes legends to calculate sq footage of walls.
Hope that helps,
Conan Witzel
