• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    neilyj
    Extent of rockfall netting
    191 Views, 10 Replies
    11-13-2012 12:08 PM
    I have a model of a platform at 29.00m cut into rock and need to find  areas where the rock cut is 2m or more as this will require netting - any ideas of a quick way to do this??
     Extract the 31m contour and see where it runs is the best I've come up with......
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Neilw
    Re: Extent of rockfall netting
    11-13-2012 12:36 PM in reply to: neilyj
    Would not a CUT/FILL depth analysis work?
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    neilyj
    11-13-2012 12:45 PM in reply to: Neilw
    The excavation surface vs a 31m plane surface??
    neilyj
    Neilw
    11-13-2012 12:48 PM in reply to: neilyj
    I don't understand your scenario. I assumed you have a proposed surface and want to determine where the cuts are >2m vs. the existing. What do you have to work with?
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    neilyj
    11-13-2012 01:04 PM in reply to: Neilw
    Yes I have a proposed surface and I'm only really interested in the portion that is below rockhead and is higher than 2m above the platform level
    neilyj
    Neilw
    11-13-2012 01:30 PM in reply to: neilyj
    In the ranges for the depth analysis, only include those values that fall within the desired parameters.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    BrianHailey
    11-13-2012 03:50 PM in reply to: neilyj
    No. Create a volume surface of your platform and your rock surface. Run an elevation analysis on the volume surface. Anywhere the elevation of the volume surface is greater than 2m is where you will need the protection. You can then stylize the volume surface and to display those areas automatically if the design changes.
    Neilw
    11-13-2012 04:11 PM in reply to: Neilw
    I assumed you knew how to create a cut/fill analysis. My apology for not being more explicit.
    WIN 7 64 PRO
    RADEON 6450, 1 GB
    neilyj
    11-14-2012 12:25 AM in reply to: BrianHailey
    Thanks Brian I'll try that ....
    This will identify the locations where the rock netting is required but the next task is to compute the area of the rock face to be netted.
    Perhaps draw a boundary around the affected areas, apply as outer boundary and review the 3D area surface properties??
    neilyj
    Valued Contributor
    11-14-2012 05:59 AM in reply to: neilyj
    I just checked and I believe in the Legend table for volumes you can add 3d area or 2d area.  We use it all the time in the slopes legends to calculate sq footage of walls.
    Hope that helps,
    Conan Witzel
