• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Exporting data to HEC-RAS Format
    489 Views, 7 Replies
    12-01-2012 03:55 PM
    I created a surface and a stream centerline alignment and ran cross sections to prepare to export to HEC-RAS.
    I go to Output tab / Export panel / Export to HEC_RAS / and in the table It shows my surface (EG2) and
    Site but when I click the alignment down arrow and it shows only "NONE". I selected the greem box to pick my
    alignment and it apeared to pick it but it does'nt show my alignment called "CL CREEK"  in the dialog box.
    And it is similar to my cross section options. I went ahead and tried to export it but my GEO file has zero bytes
    Thanks John Wilson
    Please use plain text.
    *Expert Elite*
    Neilw
    Re: Exporting data to HEC-RAS Format
    12-01-2012 05:29 PM in reply to: johnwilson0805
    I suggest you search the news group on the topic. There are several posts about problems with this tool. I personally decided not to invest time trying to work through the problems.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Valued Mentor
    fcernst
    12-02-2012 06:32 AM in reply to: johnwilson0805
    Did you try playing with the Site dropdown. The Alignment may have been put in a Site that you didn't expect?
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Active Contributor
    12-02-2012 09:16 AM in reply to: fcernst
    Thanks Fred for responding
    My drawing has several sites. I went thru some of them but I'll go thru all.
    Thanks again
    John
    Valued Mentor
    fcernst
    12-02-2012 10:23 AM in reply to: johnwilson0805
    Yes, make sure you look under <None> also there.
    Many times Alignments are not placed under any Sites, so they don't interact with other objects.
    Ernst Engineering
    Fred Ernst, PE
    New Member
    02-22-2013 01:02 PM in reply to: fcernst
    Anybody knows how can I export a designed work (let's say a designed surface) for Hec-RAS (.geo format) Is it possible to do it or not, and if it is what are the steps?
    I know how to export an EG to hec-ras!
    *Expert Elite*
    BrianHailey
    02-24-2013 01:48 PM in reply to: 2ndLt
    There's no difference between an EG surface and a Design surface in the eyes of Civil 3D. Just export the design the same way you would export the EG.
    New Member
    03-01-2013 02:32 PM in reply to: johnwilson0805
    OK, that's easy, but doesen't work. I mean, it doesent work to me, maybe I do some mistakes, I don't know. Tell me how you do it! Do you make form a coridor a new surface and then you export it to hec-ras or what?
    Thank you for response
