Civil 3D Forum
Exporting curved feature lines and retaining the elevations
5 REPLIES 5
1027 Views, 5 Replies
I have a series of curved feature lines in Civil 3D where the elevation varies along the length of the curve. When I export the file in AutoCAD the feature line elevations are 0. In my previous version of 2010 civil 3D this did not happen but now I am running 2012 version and I can't find a way around it.
Why does 2012 Civil 3D not export feature lines the way it did in previous versions and retain the elevations?
How can i overcome the issue?
Tracey
Tags (2)
5 REPLIES 5
mathewkol
I can't say I remember that about 2010, but if you switch to a 3D view BEFORE you do the Export, the linework will have proper elevations.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
ericcollins6932
in reply to: mathewkol
I find the same problem, Matt. Exporting to autocad, the feature lines are supposed to convert to 3d or LW plines with elevations depending on what the FL was.
I get 0 elevations out.
It used to work and is "supposed" to work. A bug?
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
sboon
in reply to: ericcollins6932
I reported this to Autodesk Support a while back.  The story I got is that this behaviour is what the programmers originally intended.  If you export a drawing from a 2d viewpoint then you get 2d objects at zero elevation, or if you export from a 3d viewpoint then you get 3d objects.  Unfortunately they could not make the feature work correctly, so they disabled it, and left it defaulted to 3d export all the time.
Recently the underlying issue with featurelines was resolved, as part of the fix that allows us to have featurelines which display linetypes correctly.  Once that happened somebody turned the switch for the export option back on, but they didn't tell anyone else.
Steve
Expert Elite Alumnus
Ienlov
When I export in WORLD ucs the feature lines after export have a 0 elevation...
We need the feature line elevation in plan and not in 3d visualization, this bug happens after civil 3d 2012...
Somebody could help me?
Ienlov
troma
in reply to: Ienlov
Did you try the solution above?
You can always switch it back to a 2d plan view & World UCS after you do the export.
Mark Green
Working on Civil 3D in Canada
Rail Community
