AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Exporting corridor to LandXML
- Highlight
- Email to a Friend
Does anybody know what happens when we try to export corridor to LandXML file? Do we get design cross sections that surveyors can import in the equipment? I need to export my cl alignment with the design cross sections.
Any suggestions?
Thank you.
Re: Exporting corridor to LandXML
- Highlight
- Email to a Friend
Have you tried it? When I exported the corridor from the tutorial file, I got a lot of the information you were asking for, plus more:
http://screencast.com/t/Q20JNaR0ERT
When you try it, I would recommend getting XML Notepad. It's a free download from Microsoft. You can get it here:
http://www.microsoft.com/en-us/download/details.as
It makes viewing XML files MUCH easier.
- Highlight
- Email to a Friend
What I find interesting is that you don't get the corridor itself upon import. My dwg doesn't have a SLG in it so I didn't check that, but I did get Corridor surfaces, alignments & profiles.
Williamson Co. Dept. of Infrastructure
Intel i7 3.33Ghz, 16Gb RAM
Nvidia Quadro 2000D
C3D 2012 SP3, C3D 2014
Win 7-64
Please mark this as the solution if it resolves your issue.
- Highlight
- Email to a Friend
Thanks to both of you for your responses.
What I need is some way to export my road alignment with design cross sections (subgrade). It would be even better if I could find some way to preview these cross sections after export (some kind of window - LandXML viewer similar to preview/edit cross sections in C3D). This would allow me to check cross sections before giving them to surveyors.
Thank you
- Highlight
- Email to a Friend
Brian,
Thank you for your help. I have downloaded XML editor. If I try to export my design to landxml it shows all kinds of extra information. What I need is to find some way to export my road alignment, profile and design subgrade cross sections. Rest of the stuff is confusing for my surveyors. If you have any suggestions, let me know.
Thank you
- Highlight
- Email to a Friend
Importing into data collectors is a pretty broad topic. It depends on what software they have in the office, what software they have on the data collectors, what type of data collectors....
Have you tried the slope stake reports? I attached a PNG of the setting I used. I sampled the "Pave" and "Datum" links from my corridor. I also attached the exported report. It does categorize them by type, so all the "Pave" is together and the "Datum" is together.
AutoCAD Expert Elite
AutoCAD Civil 3D 2013 Certified Professional
C3D 2013 (SP1) (HF 3.0)
C3D 2014 (Testing)
Win 7 Pro, 64-bit
- Highlight
- Email to a Friend
All the information to recreate the corridor seems to be in the XML file - it just doesn't get recreated.
How then does one send a corridor created in 2013 to a user running an earlier version??
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
Hi
The corridor is not exported even though you are using the same version of AutoCAD Civil 3D.
The data to recreate the corridor are in XML, but it is not recreated.
thank you
*Expert Elite*
MaxiCAD Informática
www.maxicad.com.br
- Highlight
- Email to a Friend
My thoughts exactly. Also, if you think along those lines, when I import other LandXML items, such as alignments, profiles, points, I don't have to do anything to the "design" parameters of them to get what the initial intent was. If I use that same thought process, there's no way to even import the data associated with the corridor and get the same designed corridor result. The corridor essentially has to be rebuilt, totally defeating the purpose, IMHO.
Nvidia Quadro 2000D
Win 7-64
- Highlight
- Email to a Friend
I guess that the corridor wouldn't be dynamic if it could be imported via XML as the assemblies would not be exported in the XML file but what is the point of having the export option in the first place??
