• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Exported ESRI Shape files gor corrupt after a few uses
    143 Views, 4 Replies
    09-03-2009 01:44 PM
    Our GIS department inforomed me the other day that .shp files we have been exporting to them go corrupt after a few uses. Has anyone else had thi problem or know f a fix? Edited by: bydesign99 on Sep 3, 2009 8:44 PM
    Please use plain text.
    *Murph
    Re: Exported ESRI Shape files gor corrupt after a few uses
    09-03-2009 02:35 PM in reply to: bydesign99
    Sounds like the GIS dept may not know how to property use the files. What
    software are they opening the shp files in?
    Murph
    www.map3d.wordpress.com
    "bydesign99" wrote in message news:6248880@discussion.autodesk.com...
    Member
    Re: Exported ESRI Shape files go corrupt after a few uses
    09-03-2009 03:07 PM in reply to: bydesign99
    They use ESRI version 9.3.1, we use Civil 3D 2010. Are there any special considerations for using exported shape files in ESRI? I think they may have been using the files directly to avoid file redundancies, but later had to import the data to keep it from corrupting. We frequently exchange data back and forth for a very large project, never had a problem with importing.
    *Murph
    09-03-2009 03:32 PM in reply to: bydesign99
    Saying they use ESRI version 9.3.1 is like you saying you use CAD 2010.
    There's different "verticals" for the ESRI side of things also. The shp
    format for GIS is a lot like the dxf format for CAD a standard format used
    for compatibility between different software applications. I been using
    exported shp files for years in AutoCAD Map3D/Civil3D and ESRI ArcMap,
    ArcView, and Arc Explorer with no problems. What corruption problems are
    they saying they have?
    Murph
    "bydesign99" wrote in message news:6248933@discussion.autodesk.com...
    New Member
    10-22-2009 12:09 PM in reply to: bydesign99
    I have had this problem before the fix is to select the data tab and check the box Create unique key field this will link the objects to the dbf file then ArcMap will read the data with no problem. The way to fix the other shape file you already made is to open the dbf file in excel and do one save this will fix the bad shape files that the GIS people are having problems with.
    Good Luck
    Jim
