AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Export to dwg
- Highlight
- Email to a Friend
- Report Inappropriate Content
I´m trying export to dwg, and I can see all the process, but the export file is not saved.
I´m using the Autocad Civil 3D 2013 and this just happens in one specific file.
What can be the problem?
Best regards
Re: Export to dwg
- Highlight
- Email to a Friend
If this happens on one file only, sounds like it's a corrupt file. Run AUDIT and fix errors and try again.
What sort of Civil objects do you have in the file? I find gradings can be a pain to export sometimes (other times they're fine). You could also try detaching all x-refs, making sure no layers are locked and no cogo points are locked.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
Re: Export to dwg
- Highlight
- Email to a Friend
thanks for the reply
This problem occurs in two files of the same project. I already ran the command audit, fixing errors and could not export to dwg.
these files don't exist gradings or locked layers.
best regards
Re: Export to dwg
- Highlight
- Email to a Friend
mariacrs wrote:.......
What actually happens when you try?
Re: Export to dwg
- Highlight
- Email to a Friend
when I export to dwg, the program executes the command but does not record the file dwg.
Re: Export to dwg
- Highlight
- Email to a Friend
Do you have x-refs?
Make sure to run the command from model space, not in a layout.
What version are you exporting from?
And what version are you exporting to?
Re: Export to dwg
- Highlight
- Email to a Friend
I don't have x-refs in the file.
I'm exporting forom the model space.
I'm working in Civil 3D 2013, and I've tried to export from version 2013 to 2007.
Re: Export to dwg
- Highlight
- Email to a Friend
I've always had better luck using the e-transmit to save back to ealier versions.
Re: Export to dwg
- Highlight
- Email to a Friend
Try to export to something closer. I would export to AutoCAD 2013. Then open that drawing, clean it up a bit, and export again to 2007.
Re: Export to dwg
- Highlight
- Email to a Friend
my problem, independent of the version I export, I can't save the autocad file.
The comand runs but in the end don't save any file.
