AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Export to HEC RAS: Reversed Flow Direction
- Highlight
- Email to a Friend
- Report Inappropriate Content
When I export my channel and cross sections to HEC RAS using the HEC RAS export tool in C3D 2012, the channel flow direction is backwards when imported to HEC RAS and the cross sections are reversed as well. My user drew the cross section sample lines as polylines from left to right when looking downstream. I used these polylines to create the sample lines but C3D does not honor the direction of the polylines so the sections are from left to right when looking upstream. The export tool does not seem to take this into account and thus everything is backwards when imported to HEC RAS. How do we get this to work?
C3D 2012
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Re: Export to HEC RAS: Reversed Flow Direction
- Highlight
- Email to a Friend
Neil:
I am not a Hec-Ras guy but I am thinking you would need the River Analysis extension for this to work in Civil 3D.
http://labs.autodesk.com/utilities/civil3d_river/
Bill
- Highlight
- Email to a Friend
Thanks for the tip Bill. I was not aware of that tool. I'll give it a try but it is not really a permanent solution since it expires in a couple of months. I would think the HEC RAS Export tool should be capable of generating a proper file. I'll file a support ticket.
These support issues are really disruptiing my deadlines!
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
Matthew Anderson, PE
Business Consultant
Global Services
Autodesk, Inc.
- Highlight
- Email to a Friend
I am having a similar problem. I exported my flow line alignment (drawn from upstream to downstream) and cross sections to HEC-RAS. The geometry schematic in HEC-RAS shows the proper flow direction and the cross sections are stationed correctly. However, when I added my bridge model it shows the upstream x-sec as the downstream x-sec and vice versa. I'm not sure if it is a Civil 3D export issue or a HEC-RAS glitch.
Let me know if you figure anything out.
- Highlight
- Email to a Friend
I'm struggling with how to get the channel alignment oriented from upstream to downstream while HEC RAS requires the stationing to be from downstream to upstream. The HEC RAS export tool would work fine if I draw my alignment from upstream to down stream but the stationing will be wrong. How do we do this?
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
I'm not sure if this will help you, but you can manually reverse the flow direction in HEC-RAS by doing the following:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Geometric Data editor > GIS Tools > Invert Lines Table > Flip Coord. Order
- Highlight
- Email to a Friend
I saw that tool but I didn't think it was for reversing the flow direction. Won't reversing the coordinates of the channel alignment actually flip and mirror it? I don't want that.
WIN 7 64 PRO
RADEON 6450, 1 GB
- Highlight
- Email to a Friend
I believe that it does reverse the flow direction. I messed around with it and on my Geometry schematic it changes the flow direction arrow. It might be worth a try- only takes a second
- Highlight
- Email to a Friend
It flips the coordinates order of draw (ie, position 1 thru 54) determines the flow direction. Flip reverses those positions so that cooridnate pair 54 is now in postion 1.
It does NOT flip X,Y or N,E.
Business Consultant
Global Services
Autodesk, Inc.
