• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Export to Google earth
    448 Views, 4 Replies
    05-13-2011 10:38 AM
    I have a site plan that I have to place on Google earth, It is placed correctly in 'space' . However when I export to Google it does not place it correctly.. I would have thought it would have just coincidently went there somehow. Any help would be better than me just spinnin wheels
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Export to Google earth
    05-13-2011 10:51 AM in reply to: kentanner1346
    First thing I would do is double check the coordinate system you have assigned to your drawing. Are you positive your data and your drawing coordinate system match up?
    Active Contributor
    05-13-2011 11:06 AM in reply to: BrianHailey
    I'm unsure how to respond..I recieved a survey from a outside surveyor with benchmarks in northing and easting labeled on each. I then start a new blank file and with the line command simply type in the easting by the northing seperated with a comma. then that sets the point. I check this with a site coordinate-lisp to verify my point matches the surveyor's benchmark..
    Active Contributor
    05-13-2011 11:12 AM in reply to: kentanner1346
    Your drawing is at coordinates but needs a coordinate system to place it on the earth.  Right click on your drawing name in the toolspace in the settings tab and choose drawing settings.  There you can set the coordinate system such as a state plane coordinate system or UTM or whatever the surveyor used.  Then when you export to Google earth it knows where on the globe to place the linework.
    :Cheers:
    Windows 7 x 64
    12 GB Ram
    Intel Xeon Quad 3.20 GHz
    NVIDIA Quadro FX 1800
    Civil 3D 2011 V2
    Active Contributor
    05-13-2011 11:30 AM in reply to: andy.manninen
    thanks still not working but now i can get ahold of the surveyor.
