• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Export lines as shapefiles to ArcMap
    937 Views, 6 Replies
    12-15-2009 08:24 AM
    I am trying to map export shapefiles to arcmap, but it keeps telling me export did not succeed. Any suggestions?? Thank you.
    Please use plain text.
    *John Mayo
    Re: Export lines as shapefiles to ArcMap
    12-15-2009 08:37 AM in reply to: ozaukeelandwater
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13251791&linkID=9240697
    This may help. There is another I don't have time right now..
    John Mayo, PE
    Core i7 920 6GB DDR3
    Radeon 4870HD 1 GB
    Vista64
    *Murph
    12-15-2009 02:03 PM in reply to: ozaukeelandwater
    Are they basic AutoCAD lines or Civil 3D objects?
    Murph
    http://map3d.wordpress.com/
    "Ozaukeelandwater" wrote in message news:6305119@discussion.autodesk.com...
    12-15-2009 02:19 PM in reply to: ozaukeelandwater
    The lines are polyline (2D polyline).
    *Murph
    12-16-2009 04:57 AM in reply to: ozaukeelandwater
    File location and name, set the file location close to the C:\\ not buried
    in a wad of subfolders, give the file a simple name like ABC.shp
    Then of course you read John Mayo's reply right, and you are selection line
    as the type of export and selecting objects not on a locked layer. What
    attribute information are you exporting with the lines? Is the dwg a newer
    dwg or a old dwg that's been around for years? Are the polylines lwplines?
    Might try running the convert command if they are the old style polylines.
    Murph
    "Ozaukeelandwater" wrote in message news:6305376@discussion.autodesk.com...
    New Member
    mkapono
    12-16-2010 05:52 PM in reply to: *Murph
    Hi there:
    John Mayo's referenced post (http://usa.autodesk.com/adsk/servlet/ps/dl/item?si​teID=123112&id=13251791&linkID=9240697) could not be located in the Discussion archive. I have a post on the Autodesk EduComm board regarding interoperability of Student version Civil 3D and ESRI ArcMap via widget from ESRI. Is aforementioned reference still available?
    Thanks from a newb to the boards. -- Mark
    ________________________________________________
    T400-2764CTO
    Intel T9400x2@2.53GHz 4GB
    Radeon HD 3400
    MSVista x86
    Valued Contributor
    11-30-2012 10:19 PM in reply to: *Murph
    Not sure why, but I got the same error message late this evening...
    moving my target directory close to c:/  solved the problem...
    Thanks murph.
    -d
