• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Export Section information to .CSV
    80 Views, 2 Replies
    11-27-2012 03:25 AM
    Good Morning,
    My Engineer has a Hec-ras file that he has been working on and I need to change some of the sections. I don't want to re-export all of my sections to a .goe file and lose the work he has already carried out.
    Is there any way of exporting the necessary sample line information into a CSV file, as I believe this will be the best way to make the changes to the hec-ras data without losing the work which has already been carried out.
    Any help with this would be greatly appreciated.
    Kind Regards
    Louise
    Please use plain text.
    Valued Mentor
    Re: Export Section information to .CSV
    11-27-2012 05:39 AM in reply to: L0uise
    You can select the section line itself, list it, and copy the station / elevation values from the command window and paste them into your spreadsheet.
    New Member
    11-27-2012 06:14 AM in reply to: L0uise
    you can use "task pane" then use query, and filter the lines you want to know. You can make a report doing that save with the extention .csv and youre done
    if you need help making it so let me know
