• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    neilyj
    Export Corridor to earlier Civil 3D version
    151 Views, 5 Replies
    01-15-2013 03:43 AM
    Can this be done? The XML export seems to have all the information to be able to recreate it but the XML import doesn't seem to import the information
    See also http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Exporting-corridor-to-LandXML/td-p/3672598#.UPVAi2ein...
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Export Corridor to earlier Civil 3D version
    01-16-2013 08:13 AM in reply to: neilyj
    The corridors are not being included in the LandXML import scheme, I suppose since they depend on many things such as assemblies which are not supported by LandXML. If you look at the LandXML Settings in Settings tab you will see that it does not have import settings for corridors. If you also go to LANDXMLIN command you will see that corridor is not part of import.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    *Expert Elite*
    neilyj
    01-16-2013 08:31 AM in reply to: AlmasSuljevic
    I realise that the assemblies are not supported but when you look inside the XML file all the data required to rebuild a static corridor seems to be available.
    The answer to the original question would therefore appear to be it can't be done?
    Is this more evidence of the fallability of the policy of incompatible annual releases i.e. corridors can't be shared with earlier versions ?
    neilyj
    *Expert Elite*
    sboon
    01-16-2013 10:12 PM in reply to: neilyj
    As far as I know it has never been possible to import a corridor via xml, even from another drawing of the same version.  The data exported can be used by other software, particularly survey layout programs to create a static version of the corridor but without surfaces, assemblies and other components Civil3d would not be able to recreate a true corridor in another drawing.
    *Expert Elite*
    neilyj
    01-17-2013 04:50 AM in reply to: sboon
    So the upshot is the corridors cannot be shared with earlier versions of the program??
    Civil 3d again proving itself to be incompatible with itself which is a bizarre situation...!!!!
    neilyj
    *Expert Elite*
    01-17-2013 06:34 AM in reply to: neilyj
    This is a theory since I don't know much about the LandXML language. Since it is a global language, it's possible that corridors are not compatible with XML. Autodesk does not control XML that I know of so maybe it's just not possible from their perspective.
    Just a thought.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
