• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Export 2D Level Banding?
    67 Views, 1 Replies
    01-16-2013 01:46 AM
    We use 3DC for basic cut/fill models and tend to use the same banding depths so in metre intervals from -10 say to +10. To remain consistent we like to keep the banding the same. I wondered if there was any way of exporting a banding set or colour scheme from project to project or surface to surface.....
    Please use plain text.
    Distinguished Contributor
    Re: Export 2D Level Banding?
    01-16-2013 02:41 AM in reply to: MattBithell
    Yes there is... go to the toolbox tab on your toolspace window. If you run UKIE or ANZ templates you should find under "additional tools" that you have "surface analysis - export to a file", and similarly to import to a file. I use this all the time and I recommend reading the thread that put me onto it: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Custom-color-range-for-surface-elevations/td-p/339635... In it you will find some useful tips from Andrew Puller on how to add a bit of flexibility.
    Regards
    - Mick
    Civil3D 2013 (infrastructure suite) ANZ (also testing 2014)
    Self-built i7-3930K, 16Gb RAM, P9X79 m/board
    SSD(system), HDD(data), GTX680, Win7Pro64
