AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Exploding a Surface Components to different layers
- Highlight
- Email to a Friend
Is there a way if I want my suface to be exploded for the components to be sent to different layers. For example if I make a building pad using the grading tool and create a surface for a design. I would like the minor and major contours to be on different layers. Same for my grading I would like my cut daylight boundary to go to a CG-Cut and fill daylight boundary to go to CG-Fill layers. Is there a way to do this? It would really streamline my work designing pads.
Re: Exploding a Surface Components to different layers
- Highlight
- Email to a Friend
I don't think you need to explode the surface. Go to Surfaces-Utilities-Extract Objects From Surface. You can then select TIN lines, contours, ect., extract them as AutoCAD entities, and place them on whatever layers you'd like.
- Highlight
- Email to a Friend
You set the layers for componants of a surface in the surface style > Display tab. Without checking right now, I believe the objects will take on those layers if they are extracted or exploded.
Not sure why you need to explode as part of your design process though. Do you just need them to be on these layers for plotting? If that's it, you can set it in the display tab and leave it at that, no explosion or extraction necessary.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
the objects must also be visible before you can extract them
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Highlight
- Email to a Friend
you would have to explode the surface, and then explode the block it creates to get the entities on their layers.
