• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Existing Corridor Error
    126 Views, 5 Replies
    01-17-2013 12:54 PM
    When trying to make an existing features cooridor when I select Target to set the existing surface I get an error
    "No target foun in the scripts."
    I have attached a word file with the error as it appears on the screen
    Edited by
    Discussion_Admin
    Please use plain text.
    *Expert Elite*
    Re: Existing Corridor Error
    01-17-2013 01:42 PM in reply to: rcallison
    First, there's nothing attached. Second, please don't attach Word doc's. Just attach the image itself.
    Jeff_M, also a frequent Swamper
    Active Contributor
    01-17-2013 01:55 PM in reply to: Jeff_M
    *Expert Elite*
    01-17-2013 02:09 PM in reply to: rcallison
    What subassembly are you using to go to the EG? Does the EG exist where they intersect?
    Active Contributor
    Re: Existing Cooridor Error
    01-17-2013 02:26 PM in reply to: Jeff_M
    I'm using the FDOT existing features subassembly from the FDOT State kit.  The subassembly is coded to tie to existing features i.e. road, sidewalk.
    *Expert Elite*
    01-17-2013 02:49 PM in reply to: rcallison
    OK, you will probably have to get someone familiar with the FDOT kit to help out.
