• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Estimating time for a project
    195 Views, 7 Replies
    12-11-2012 09:34 AM
    I’d like to get some info about estimating time needed for a project. Nothing too exact is needed. How many hours per sheet do you guys build into figuring your time needed for a project using Civil 3D
    Thanks for the help!
    Please use plain text.
    *Expert Elite*
    Re: Estimating time for a project
    12-11-2012 11:16 AM in reply to: charles.neely
    Hello Charles,
    That's a very hard question to answer when you don't know the type of project and the types of sheets required. Are you only estimating output time, meaning the project is already designed, or are you estimating design and output? Who is doing the project and do they know how to use Sheet Set Manager to help with sheet creation? What type of hardware is involved, affecting the speed at which an operator can use the data. How many different files are involved. Lots of Xref's attached? Images? Civil 3D references?
    If a template is already created and the design is done, it takes minutes to create the model views and place on sheets, but that's rarely the whole story.
    Best regards,
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Contributor
    12-11-2012 12:13 PM in reply to: tcorey
    I'm not wanting to get that deep in the weeds. Just any kind of rough information. Back of the envelope type estimate.
    *Expert Elite*
    Neilw
    12-11-2012 01:22 PM in reply to: charles.neely
    I will break a project down into tasks and then estmate the time for each task.
    Example:
    Create topography model from survey
    Layout alignments and profiles
    Create first run corridor and grading models
    Create check plan sheets & review design
    Etc.
    Not all projects have all the same stages or even the same size, so I can't imagine a boiler plate cost estimate to cover all projects. Nor can I see how a simple cost per sheet can accomodate the many variables.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Valued Mentor
    LeafRiders
    12-11-2012 05:04 PM in reply to: Neilw
    Very good question... Key is to keep track of your projects and the hours, even break that down into tasks. Highlight the project details, so a year or two down the road you have an idea. This will eventually give you a basis for your decision on answering. "How much time will this take to do". My usual response, It will take longer than you think it will.
    *Expert Elite*
    Joe-Bouza
    12-11-2012 06:20 PM in reply to: LeafRiders
    Exactly!
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Contributor
    12-11-2012 08:37 PM in reply to: charles.neely
    It really depends on if it's a commercial project or residential subdivision project. In addition, it also depends the level of experience of your designer and drafter. Here are some good examples.
    Plan and profile sheets = 1 hr to 3 hrs per sheet.
    Grading Plans = 3 hrs - 2 days
    DImensional Control Plan = 1 hr - 3 hrs
    Storm Plans = 1-3 hrs
    Water Plan & Profiles = 2-8 hrs
    Drainage Area Maps = 2 hrs - 4 hrs
    These are rough ball park figures but the site design will change several times before a first submittal. Then during the city review it will change a few more times also. It will end up taking months if a large commercial project with a few bldg or subdivision. I have several projects that the site has changed 6 times. That meant working thru all the sheets again.  Anyways hopefully this helps.
    Tony
    CAD Manager
    www.tonyscivil3dworld.blogspot.com
    Valued Mentor
    LeafRiders
    12-12-2012 07:11 AM in reply to: tony1978
    "Plan and profile sheets = 1 hr to 3 hrs per sheet.
    Drainage Area Maps = 2 hrs - 4 hrs"
    ... I would say this is completely based off of something where the process is well defined, all standards and templates are in place, and for something that is very straight forward. If I used your numbers for a complex roadway / infrastructure design and drafting project the budget would likely be exceeded in a hurry.
    I've used 3 days per plan profile sheet for complete design (exg surface, design corridor, drainage, and extras (culverts, approaches, curb and gutter, drainage features, cosmetic features, etc.), drafting (prelim / conceptual) and design drawings, checking, review, and changes and updates after client review. It's a ballpark that gets us close on most occasions.
