AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Error message - Object was open for read
- Highlight
- Email to a Friend
Re: Error message - Object was open for read
- Highlight
- Email to a Friend
Annotative Text is buggy in the 2008 version. Usually, if the text gets "frozen", you can clear it up by typing "AUDIT". Note that you can answer "No" when it asks you to fix errors, and the audit will go much faster.
This problem was fixed in C3D 2009, but as usual, was never fixed in C3D 2008.
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
- Highlight
- Email to a Friend
I have the same problem with text which isn't annotative in C3D 2012, so I don't think it's totaly fixed yet. Any Idea how to solve the problem so I can edit the text?
- Highlight
- Email to a Friend
A user of mine is experiencing the same problems with C3D 2012. Audit fixes it, but not for long. I've applied the 2012 performance Hot Fix, not that that was supposed to take care of this issue, but just to let people know it's about as up to date as can be.
http://autocad-lkh.blogspot.com
- Highlight
- Email to a Friend
I'm having the very same problem ... been working and searching on this for two days. This is happening on two computers (not everyone) with same dwg. I've tested same dwg on different computers. I tried Audit and it works once but then goes back to behaving the same. I removed Civil 3D 2011 from computers and did a repair on 2012 (thought that may fix it but to no avail). I put in a Tech Support yesterday and haven't heard back yet. When I do, I'll definitely let you know what's said. This is a headache!
- Highlight
- Email to a Friend
I have had this issue also. Almost every time I need to do anything to text I have to audit it first then regen to see it. This is very aggravating
- Highlight
- Email to a Friend
I did hear from Tech Support...they said this was a known issue and is in their development team and is scheduled for a fix in SP1. A workaround is set the DTEXTED to 1. So far that has seem to work.
- Highlight
- Email to a Friend
Having the same problem, but not only with text editor. Move, copy and other editing commands also will not work when this error occurs. The fix noted about 'dtexted = 1' seams to be working for me as well.
- Highlight
- Email to a Friend
FYI - Setting DTEXTED to 1 worked one time then text froze in new postion.
- Highlight
- Email to a Friend
FYI2 - Recovered the drawing and having DTEXTED set to 1 works just fine. Thanks for the workaround.
