• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Error message - Object was open for read
    2982 Views, 9 Replies
    11-27-2008 04:06 PM
    I very frequently get the above message, "Oject was open for Read". Its to do with annotative text objects which I just recently started using. When I get the message the piece of text I am trying to make changes to is frozen, cant delet it or anything, can anyone tell me whats up?
    Please use plain text.
    Re: Error message - Object was open for read
    11-28-2008 06:42 AM in reply to: darowe
    Are you using C3D 2008?
    Annotative Text is buggy in the 2008 version. Usually, if the text gets "frozen", you can clear it up by typing "AUDIT". Note that you can answer "No" when it asks you to fix errors, and the audit will go much faster.
    This problem was fixed in C3D 2009, but as usual, was never fixed in C3D 2008.
    -- Sinc
    http://www.ejsurveying.com
    http://www.quuxsoft.com
    Sinc
    New Member
    Cartosmurf
    08-23-2011 07:05 AM in reply to: Sinc
    I have the same problem with text which isn't annotative in C3D 2012, so I don't think it's totaly fixed yet. Any Idea how to solve the problem so I can edit the text?
    hardin
    08-23-2011 08:49 AM in reply to: Cartosmurf
    A user of mine is experiencing the same problems with C3D 2012. Audit fixes it, but not for long. I've applied the 2012 performance Hot Fix, not that that was supposed to take care of this issue, but just to let people know it's about as up to date as can be.
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    oceanside
    11-09-2011 08:40 AM in reply to: hardin
    I'm having the very same problem ... been working and searching on this for two days.  This is happening on two computers (not everyone) with same dwg.  I've tested same dwg on different computers.  I tried Audit and it works once but then goes back to behaving the same.  I removed Civil 3D 2011 from computers and did a repair on 2012 (thought that may fix it but to no avail).   I put in a Tech Support yesterday and haven't heard back yet.  When I do, I'll definitely let you know what's said.  This is a headache!
    the best is at the beach!
    New Member
    Craig_B
    11-16-2011 10:59 AM in reply to: oceanside
    I have had this issue also.  Almost every time I need to do anything to text I have to audit it first then regen to see it.  This is very aggravating
    oceanside
    11-16-2011 11:03 AM in reply to: Craig_B
    I did hear from Tech Support...they said this was a known issue and is in their development team and is scheduled for a fix in SP1.  A workaround is set the DTEXTED to 1.  So far that has seem to work.
    New Member
    mkindschi
    01-23-2012 12:42 PM in reply to: oceanside
    Having the same problem, but not only with text editor.  Move, copy and other editing commands also will not work when this error occurs.  The fix noted about 'dtexted = 1' seams to be working for me as well.
    New Member
    slitsheim
    12-22-2012 08:11 PM in reply to: darowe
    FYI - Setting DTEXTED to 1 worked one time then text froze in new postion.
    New Member
    slitsheim
    12-22-2012 08:24 PM in reply to: darowe
    FYI2 - Recovered the drawing and having DTEXTED set to 1 works just fine. Thanks for the workaround.
