AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Error Message: "Undefined group code 10 for object on line 2106."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Invalid or incomplete DXF input -- drawing discarded.
I created stream profiles in RASPLOT using its DXF Editor but when I try to open up the DXFs in AutoCAD I get the above error. Any help would be appreciated. Thanks.
Re: Error Message: "Undefined group code 10 for object on line 2106."
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The DXF code 10 (usually an insertion point, first point, etc.) must have invalid information at that line. The thing to do is open the DXF file, scroll to that line and either fix the input or delete the input (might be several line) for that object.
If you are unable to do it yourself, post the dxf file here.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you ever find a solution to this? I am having the same message for the insertion point for multi-text. Code 10 looks just fine to me, and it will load fine in R13 but throws out the error in AutoCAD 2013.
0 MTEXT 5 330 100 AcDbEntity 8 Layer_000 100 AcDbMText 10 663.226087 20 215.597374 30 0.0 40 6.69 41 740.711721 71 1 72 1 3 Units = U.S. Survey Feet\P\P\P CURVE TABLE\P\P( CURVE DELTA RADIUS ARC TANGENT CHORD CHORD BEARING)\P( ===== ============ ========= ========= ========= ========= =============)\P( C 3 60 171°47'23" 39.67' 118.93' 552.68' 79.13' S 71°33'54" E)\P( C61 147°45'08" 37.39' 96.43' 129.35' 71.85' S 79°09'35" E)\P( C62 131°58'22" 34.23' 78.84' 76.83' 62.53' S 70°06'53" E)\P( C105 106°4 1 4'35" 52.14' 97.14' 70.13' 83.69' S 62°01'14" E)\P( C106 110°27'55" 50.00' 96.40' 72.03' 82.15' S 61°45'14" E)\P 7 COURIER_NEW
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If it loads correctly with Civil 3D, but not with AutoCAD, I would open in Civil 3D and then ExportoAutoCAD to make a drawing AutoCAD can use.
Redding, CA
