Entity isn't planar
Entity isn't planar
neilyj666
Mentor Mentor
Message 1 of 24
Entity isn't planar
neilyj666
What does this mean (see screenshot) and how do I get around it??
Trying to convert the magenta object to feature line and the message appears - the object is a polyline and all Z values are zero.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (23)
Message 21 of 24
neilyj666
Couldn't wait - I just used the file I posted and thanks again - thats brilliant; no idea what the code does but it works great.
I also tried the MIRROR3D as per earlier link which worked but the lisp is much easier
Message 22 of 24
I used "flatten" command and it fixed the issue.
Message 23 of 24
IanMcClain
I'm having the same or similar issue:
I tried the normalize.lsp in 2023 and 2025, no errors but the objects still produce an error when trying to convert to feature lines>
Ian McClain
Message 24 of 24
pendean
Community Legend
Community Legend
Ask in the C3D forum (software you are suing) and share a DWG sample with your new post (and/or do the same here) @IanMcClain
