• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    Valued Mentor
    sjg
    End of Corridor
    315 Views, 7 Replies
    08-31-2011 11:52 AM
    Haven't really done to much with corridors, not sure best way to tie the end of the corridor into existing ground. See image
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    Please use plain text.
    Re: End of Corridor
    08-31-2011 01:02 PM in reply to: sjg
    One method is to draw a featureline along the end of the corridor and use a grading to the EG.
    Re: End of Corridor
    09-01-2011 02:20 AM in reply to: sjg
    Sjg, that depends. By your image it looks like your road just ends, perhaps to be continued ar a future date. Is this the case? Or is it supposed to tie back into an existing road which maybe isn't shown. Your answer depends on what you want to do there.
    In most cases I just leave it as-is without bothering to do any cleanup. The extra work is often pointless unless it's your intent to render this project or if you NEED finished contours.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Valued Mentor
    Valued Mentor
    sjg
    Re: End of Corridor
    09-01-2011 06:19 AM in reply to: mathewk
    We are going to show it as possible future extension, but most likely will never be extended. So I would like to show finished contours
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
    Re: End of Corridor
    09-01-2011 07:06 AM in reply to: sjg
    Then Jeff's suggestion is about all you can do. It's pretty much what happens in the field anyway. Paste the corridor and grading surfaces into a new composite surface for your finished model.
    Matt Kolberg
    Joe-Bouza
    Re: End of Corridor
    09-02-2011 09:44 AM in reply to: mathewk
    I have used a M&O sub on the end set to match slope and 0.0001 thickness.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Neilw
    Re: End of Corridor
    09-02-2011 10:09 AM in reply to: Joe-Bouza
    Aside from using a grading you can also treat the end like an intersection by creating an alignment representing the end of the road, sampling the corridor surface and either applying an assembly to the alignment or create a grading from a featureline generated from the alignment+profile. It's probably a prohibitive amount of work but it is an option.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Valued Mentor
    Valued Mentor
    sjg
    Re: End of Corridor
    09-02-2011 10:28 AM in reply to: Neilw
    I will probably just go with Jeff' suggestion and generate a feature line and gradings.
    Steve Goessling
    Land Consultants
    Windows 7, 64 bit
    16 GB RAM
    Nvidia Quadro 600
