• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Eliminating a segment in a lot line
    108 Views, 2 Replies
    10-09-2012 12:16 PM
    I have a subdivision plat that I'm working on with a curved lot line.  When I label this particular lot line, Civil 3D labels it like it's two different segments.  In other words, instead of labeling the line as a 100 foot long arc with a radius of 100 feet, it labels it as a 60 foot arc and a 40 foot arc.  I can't figure out how to combine the two segments.  All of the lots lines were created from polyline objects, and there was no break in the original line work (nor is there any indication of a break in this location when I select it).  Anyone know how to fix this and get it to label correctly?
    Kurt
    Please use plain text.
    Re: Eliminating a segment in a lot line
    10-10-2012 09:53 AM in reply to: tr4driver
    Is there a lot line for adjacent lots intersecting this curve? If so, you need a label style set to "Span outside segments". Then, as long as the label is to the side of the unbroken arc you will get the full curve data, flip the label and you will get the segmented data.
    10-11-2012 02:02 PM in reply to: Jeff_M
    Thanks for the reply Jeff.  I found out there there was a shorter line segment laying directly on top of the longer correct line segment.  C3D was creating an in-line PI at the end of the shorter segment.  However, whenever I clicked on the line, I was selecting the longer segment and didn't realize there was a shorter one underneath it.  It took me a while to figure that out.  Once I figured out what was going on, I selected the shorter line segment with a window and deleted it.  Everything is labeled correctly now.
    Kurt
