• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    *Burgasser, Drew
    ElevationAt method along asym vc
    86 Views, 3 Replies
    12-01-2003 05:01 AM
    The ElevationAt method for aeccprofiles seems to be giving incorrect
    elevations along an aysmmetric vertical curve.
    Drew Burgasser
    CAD Masters, Inc,
    www.cadmasters.com
    Please use plain text.
    *Rogerson, Michael
    Re: ElevationAt method along asym vc
    12-01-2003 11:19 PM in reply to: *Burgasser, Drew
    Drew,
    Hoping for more detail... what is the configuration of the curve (sag,
    crest, grade in/out and lengths 1 & 2) ? Also, what formulas/calculations
    are you using to verify the elevations?
    thanks in advance,
    Mike
    "Drew Burgasser" wrote in message
    news:EA46FEAF4B4612A439C9212170401D05@in.WebX.maYIadrTaRb...
    > Thanks,
    > Drew Burgasser
    > CAD Masters, Inc,
    > www.cadmasters.com
    *Burgasser, Drew
    Re:
    12-02-2003 02:37 AM in reply to: *Burgasser, Drew
    Michael:
    The configuration doesn't really matter. I got inaccurate elevations for the
    following 3 configurations:
    crest, 75', 100', 1.76%, -1.55%
    sag, 150', 125', -1.55%, 0.61%
    crest, 200', 100', 0.61%, -0.84%
    I compared the ElevationAt values with the low point and high point
    elevations listed in Profiles => Edit Profile... => Select PVI. They don't
    match. So either one or both is/are wrong. My guess is that the listed
    elevation under Select PVI is correct. The HighPointElevation and
    LowPointElevation property for the asym vc also seems to list the correct
    value.
    Unrelated, the begin and end station properties for the asym vc are also
    listing incorrectly.
    I can send you a drawing and code if you like.
    Sincerely,
    Drew Burgasser
    CAD Masters, Inc.
    "Michael Rogerson" wrote in message
    news:1F3F1CE494515B1515EB152A024AB7A8@in.WebX.maYIadrTaRb...
    > Drew,
    > thanks in advance,
    > Mike
    > > Thanks,
    > > Drew Burgasser
    > > CAD Masters, Inc,
    > > www.cadmasters.com
    *Rogerson, Michael
    Re:
    12-02-2003 03:40 AM in reply to: *Burgasser, Drew
    Drew,
    Much thanks - seems simple to check from your reply, I'll verify and write
    to you directly if I have any questions.
    Mike
    news:1A753848635E9D667D2BD9052DB61D51@in.WebX.maYIadrTaRb...
    > Michael:
    the
    don't
    > value.
    > Sincerely,
    > Drew Burgasser
    > CAD Masters, Inc.
    message
    > > Drew,
    > > thanks in advance,
    > > Mike
    > > > Thanks,
    > > > Drew Burgasser
    > > > CAD Masters, Inc,
    > > > www.cadmasters.com
