• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Elevation Banding Table - Adding % of Total Area
    133 Views, 1 Replies
    09-27-2012 02:28 PM
    Hi Everyone,
    Is there a way to add a column that would show for each elevation range the percentage of the total area?
    Steve
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Elevation Banding Table - Adding % of Total Area
    10-01-2012 06:49 AM in reply to: spinto
    Hi Steve,
    I don't think it's possible to do it in out of box tools but I think you may be able to modify your table style to add Areas for each range. That would give your something to work on.
    Then you would need to somehow create a formula or value that puts it all togeter (total area) and then divide each individual volume by total, yielding percentage. Not very pretty but with some scripts or expressions you may be able to get it; not necessary in the same table but you would be able to get your values.
    As an alternative, you may create your entire table in Excel and just import it into your drawing.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
