• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Re: Editing Default User Contours in Styles
    12-03-2012 07:26 AM in reply to: Joe-Bouza
    Maybe it's me not following your thoughts Joe, but here's my question: How do you have a dummy volume surface set up in your template and then use it for a real application?  Wouldn't you have to swap the base & comparison surfaces from whatever dummy surfaces you used to set it up, to the real surfaces you want to use?  Or what is the workflow you're suggesting?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    joshua.prettyman
    12-03-2012 07:27 AM in reply to: Joe-Bouza
    You'd just need two dummy surfaces to paste other stuff into, and have those referenced by the volume surface. It would work in this instance, but I use them multiple times in the drawing and it wouldn't be practical for me to include that many surfaces.
    *Expert Elite*
    12-03-2012 07:34 AM in reply to: joshua.prettyman
    Oh, I get it. You paste into or just edit the dummy base & comparison, rather than editing the volume surface to suit.  Seems a bit cumbersome, you have to know where you're going before you start & all that.
    1. I think you should have the option within the properties of a volume surface to switch the Base & Comparison surfaces.
    2. I think the 'Analysis' tab of a Tin Surface properties should be located within the surface style instead.  That way it would be so much easier to get multiple surfaces with the same elevation analysis, and would also solve the issue of this thread.
    *Expert Elite*
    Joe-Bouza
    12-03-2012 07:35 AM in reply to: troma
    Sure:
    Surface1: = _EG = dummy surface for base. Add to it a few dummy points
    Surface2: = _FG = dummy surface for comparison. Add to it a few dummy points
    Surface3: = VolumeSurface. Create in template with the _EG vs _FG as base and comparison
    Once actual EG and FG are made paste into _EG & _FG respectively and remove the dummy points.
    If you were compelled to swap just paste accordingly
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
