AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Editing Default User Contours in Styles
- Highlight
- Email to a Friend
- Report Inappropriate Content
In the surface styles dialog under analysis you can edit elevations, colors, etc. EXCEPT for user contours. What I would like to do is edit these for user contours, then when I created it there would be a default of sorts.
So the question... is there any way to set a default for user contours in the style?
Re: Editing Default User Contours in Styles
- Highlight
- Email to a Friend
I don't think there is. You can have a style that is set to display them, but you can't create them until the surface is created.
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
- Highlight
- Email to a Friend
Although, you can setup a "seed" suface with some dummy data to set the default user contours in the template with all the bells and whistles you want, add the data and the user contours will show
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
Joe,
Very nice. Way to think out of the box.
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
- Highlight
- Email to a Friend
Sometimes we all get lucky, Bro ![]()
That technique can be taken to all c3d objects, but can create a messy template
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Highlight
- Email to a Friend
I use the volume surface and the 0 contour to determine daylights where the grading can get rough. So a dummy surface doesn't work in this instance.
If there's no way than there's no way though. Thanks for your help!
- Highlight
- Email to a Friend
Why not? create another dummy and the volume surface in the template
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
- Highlight
- Email to a Friend
They're used multiple times throughout the drawing. It would simplify things a bit though. Thanks.
- Highlight
- Email to a Friend
For that to work wouldn't you need the option to switch the Base & Comparison surfaces within the Volume surface?
(For the record, you should have that option anyway IMHO.)
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
Pardon; I lost track of your thought? Why would you have to switch anything around?
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
