AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Edit grading
- Highlight
- Email to a Friend
Hi everyone,
I´m having some trouble about edit grading and hope that someone can help me.
I´ve done a grading "applying to entire lenght" but after done that I realized that I needed to do some located contentions. Is it possible to edit the grade for not applying it to entire lenght?
When I go to the modify tab, edit grading, it does not appears the option "apply to entire lenght?"
Civil Engineer - www.trentoengenharia.com.br
Autocad Civil 3D 2013 - Infrastructure Design Suite
Windows 7 64 i7 2600 @3.40GHz 8GB Ram GeForce GTX 550
Re: Edit grading
- Highlight
- Email to a Friend
I don't believe so. From what I remember once you choose to grade from the entire length you are stuck. You will need to delete the grading and use new options.
Civil 3D 2013 64 bit SP1
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
NVIDIA Quadro FX 580
explodetheblock.wordpress.com
Re: Edit grading
- Highlight
- Email to a Friend
That´s what I thought so,
unfortunately, my surface is "stitched" on the inside, if I do a new grade, with a new infill I´ll lose all my work
Re: Edit grading
- Highlight
- Email to a Friend
You are by no means stuck. You can definitely make edits to it.
http://www.youtube.com/watch?v=WbuCVV_hreI&list=UU
Cansel - Autodesk Division
http://www.cansel.ca/
Re: Edit grading
- Highlight
- Email to a Friend
It still amazes me of all the little things I don't know about that can make such a big deal in a workflow. Thanks, Matt!
Windows 7 Pro 64
Intel Xeon 2.93GHz
24GB RAM
Re: Edit grading
- Highlight
- Email to a Friend
Any time.
Re: Edit grading
- Highlight
- Email to a Friend
Hi!!! Thank you so much for that solution!
But I still have a question about the creation of a transition. In autocad C3D 2013, it offers me an option to create transition, after that, if you press enter, it won´t work, because I only have 1 grading, no slope difference. Also, it offers me the option of [Points], so, I press P, and create a transition, is that correct?
I ask that because I thought that the creation of a transition was only used when I had different slopes at the same grade encountering each other.
Re: Edit grading
- Highlight
- Email to a Friend
I cant access Youtube here. What is the solution?
The transition tool can create a slope transition on the fly or expect at least two gradings along the feature line seperated by a gap. grading 1 would have slope 1 , grading 2 slope 2 and the transition flow btween them
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Re: Edit grading
- Highlight
- Email to a Friend
Just add a transition, actually a few of them.
Re: Edit grading
- Highlight
- Email to a Friend
I don't know what you mean Mariana. It's working in 2013 the same way as it is in my video. I have no "P" option when adding transitions.
