• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    marirf
    Edit grading
    209 Views, 18 Replies
    10-25-2012 07:17 AM
    Hi everyone,
    I´m having some trouble about edit grading and hope that someone can help me.
    I´ve done a grading "applying to entire lenght" but after done that I realized that I needed to do some located contentions. Is it possible to edit the grade for not applying it to entire lenght?
    When I go to the modify tab, edit grading, it does not appears the option "apply to entire lenght?"
    Mariana
    Civil Engineer - www.trentoengenharia.com.br
    Autocad Civil 3D 2013 - Infrastructure Design Suite
    Windows 7 64 i7 2600 @3.40GHz 8GB Ram GeForce GTX 550
    Please use plain text.
    Re: Edit grading
    10-25-2012 07:35 AM in reply to: marirf
    I don't believe so. From what I remember once you choose to grade from the entire length you are stuck. You will need to delete the grading and use new options.
    -Dustin
    Civil 3D 2013 64 bit SP1
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    NVIDIA Quadro FX 580
    explodetheblock.wordpress.com
    Active Member
    marirf
    Re: Edit grading
    10-25-2012 07:41 AM in reply to: dasindog
    That´s what I thought so,
    unfortunately, my surface is "stitched" on the inside, if I do a new grade, with a new infill I´ll lose all my work
    Mariana
    *Expert Elite*
    Re: Edit grading
    10-25-2012 08:15 AM in reply to: marirf
    You are by no means stuck.  You can definitely make edits to it.
    http://www.youtube.com/watch?v=WbuCVV_hreI&list=UU_5gUiM33gZ5nCshE0gp-jA&index=40&feature=plcp
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Re: Edit grading
    10-25-2012 09:37 AM in reply to: mathewk
    It still amazes me of all the little things I don't know about that can make such a big deal in a workflow. Thanks, Matt!
    -Dustin
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    *Expert Elite*
    Re: Edit grading
    10-25-2012 09:39 AM in reply to: marirf
    Any time.
    Matt Kolberg
    Active Member
    marirf
    Re: Edit grading
    10-25-2012 11:30 AM in reply to: mathewk
    Hi!!! Thank you so much for that solution!
    But I still have a question about the creation of a transition. In autocad C3D 2013, it offers me an option to create transition, after that, if you press enter, it won´t work, because I only have 1 grading, no slope difference. Also, it offers me the option of [Points], so, I press P, and create a transition, is that correct?
    I ask that because I thought that the creation of a transition was only used when I had different slopes at the same grade encountering each other.
    Mariana
    *Expert Elite*
    Joe-Bouza
    Re: Edit grading
    10-25-2012 11:47 AM in reply to: marirf
    I cant access Youtube here. What is the solution?
    The transition tool can create a slope transition on the fly or expect at least two gradings along the feature line seperated by a gap. grading 1 would have slope 1 , grading 2 slope 2 and the transition flow btween them
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    Re: Edit grading
    10-25-2012 11:48 AM in reply to: Joe-Bouza
    Just add a transition, actually a few of them.
    Matt Kolberg
    *Expert Elite*
    Re: Edit grading
    10-25-2012 12:03 PM in reply to: marirf
    I don't know what you mean Mariana.  It's working in 2013 the same way as it is in my video.  I have no "P" option when adding transitions.
    Matt Kolberg
