• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Edit Units for Pipe Properties
    155 Views, 5 Replies
    01-15-2013 04:13 PM
    I am setting up a parts list using The Metric Catologue. In the Pipe Properties the Pipe Diameter shows mm but the Minimum Curve Radius shows inches. The Units are Greyed-Out. Is ther a way to edit these Units?
    Kirk Dixon
    Please use plain text.
    Product Support
    Re: Edit Units for Pipe Properties
    01-17-2013 09:03 AM in reply to: kdixon
    Did you by chance start an imperial drawing and point to the metric catalog with SETNETWORKCATALOG?
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    Being Civil Facebook
    01-17-2013 09:27 AM in reply to: SethHall
    No, All my Templates have a Metric Base. We never work in Imperial here. [KRD-EMAIL SIG]
    Product Support
    01-18-2013 12:56 PM in reply to: kdixon
    After a little poking around, the unit information is stored in this file: AeccPartParamCfg.xml Typically located here:
    C:\ProgramData\Autodesk\C3D 2013\enu\Pipes Catalog\Aecc Shared Content
    <AeccDfParameter name="MCR" desc="Minimum Curve Radius" context="MinCurveRadius" index="0" datatype="Float" usage="Double_Distance" unit="in" visible="True" internal="True"/>
    You should be able to change the unit value above and it should populate in Civil 3D.
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
    01-21-2013 07:53 AM in reply to: SethHall
    Thank you very much, that worked. Appreciate it!! [KRD-EMAIL SIG]
    Product Support
    01-22-2013 05:55 AM in reply to: kdixon
    Great!! Glad to help!
    Seth Hall
    Product Support
    GCSO - CSS - FTS
    Being Civil
    Being Civil Twitter
