AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Edit Pipe Network in Plan
- Highlight
- Email to a Friend
How can I edit (graphically) my pipe network in plan view without losing my elevations everytime I move a node? Everytime I move a node I have to re-enter my invert elevations. Is there some way to "lock" my inverts? It may be useful to know my pipes have no structures linking them (water line).
Re: Edit Pipe Network in Plan
- Highlight
- Email to a Friend
I am still having this issue. Any suggestions?
- Highlight
- Email to a Friend
1. Copy the elevation from the properties menu before grip editing, and paste it back in after.
2. Instead of grip editing the pipes, use the structure.
3. Set your OSNAPZ to 0
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
- Highlight
- Email to a Friend
Another way is to use point filters. There are several ways to do this, but simplest, I think, is to click on the pipe, grab the grip you want to move in plan view, type in ".Z" (note the period first, then the letter Z). The command line asks you to select the Z reference elevation to use, so snap once more to the same grip edit, then snap to your new location. In this manner, you will retain the exact Z elevation that you began with. Now, whether or not that is the final elevation you want is another question, but at least it won't snap to zero, forcing you to edit your pipe elevations evertime you grip edit one.
As Andrew Ingram mentioned earlier, moving the structures where possible is the best idea as the elevations stay constant without having to use any tricks like point filters, etc.
- Highlight
- Email to a Friend
You say you're not using structures. My advice: use structures! You can set them up to not plot.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
