AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am working on a project where I need to make some calculations on the earthwork.
The first 0.5m on the existing ground is a layer of top soil, and therefore can’t be used in the fill areas. When I want to make a mass haul diagram, how do i make the calculation so the layer of top soil isn’t included? And can I make a calculation where the volume of the top soil layer is calculated.
-thanks
Re: Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Copy your exisiting surface to a new Name. Lower the surface .5 meters. You can deal with the topsoil later.
Bill
Re: Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the reply
Though that was what I should do, but how do you copy a surface? Do I need to export it, and then import it again?
- Thomas
Re: Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ohh okay, that was a stupid question. Found out that its possible to use the copy command.
Thanks for answering, got it to work.
Re: Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Whilst copying will work, if you have a surface that you want to lower, but also have it linked to the original surface (probably not a problem with an existing surface, as it "shouldn't" change, but this is just an overall tip), you can create a new, blank surface, paste the original surface into it, then through the Definition->Edits for the surface you can lower/raise the surface.
Just an FYI ![]()
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Re: Earthwork
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Civil 3D is a great construction document tool. IF you need to do design that include the ability to look at topsoil, rock, contaminated or structurally unsound soil then give SITEOPS a look. It is a great software for doing quick grading plans then take to output files into Civil3D to finish documents. SITEOPS can grade a 100 acre site in less than an hour and a one acre site in about three minutes.
David Settlemyer
Director of Civil Engineering
SITEOPS
