AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
is the case remove the boundary & apply a mask. A mask will still show the
data in profile.
John
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Create a new surface profile for 25+00 to 26+00.
When you create a surface profile, and specify the stations to use, you
cannot later change the sampled stations.
Jeff
"bgriffin291" wrote in message news:6387200@discussion.autodesk.com...
> When I originally created the surface profile I stopped it at 25+00. The
> surface continues to 46+00, I just didn't need all that extra profile.
> I'm only designing 1000' of road.
> You cannot modify an EG profile using the layout tools either. I believe
> that because it is surface dependent using the line command is not an
> option.
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You most certainly can change the sampled stations in a surface profile. Just grip edit the alignment to make it longer and the corresponding sampled EG profile will increase proportionally. (Providing, of course, there exists viable EG surface under the increased alignment length, as pointed out by others here.)
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
with. When you specify a station range to sample, as the OP noted was done,
you cannot later change it.
"castled071049" wrote in message news:6387506@discussion.autodesk.com...
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have seen multiple cases in C3D 2013, where the full alignment was sampled, but yet stretching the alignment after the EG profiles are drawn - does not automatically stretch the EG profiles.
The fix for this is to go into Profile Properties, on the Profile Data tab, change the Update Mode to Static, press Apply, then change it back to Dynamic and press Apply.
Having said that, I just created an alignment and profile in a dummy drawing and it works like you would expect, maning that you stretch the alignment, and the EG profiles stretch. So I can't recreate the problem on demand, but I know I have seen it on multiple occasions.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the update on this Randy.
Could this be one of those issues that only appears when you open an previous version file on 2013?
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
Re: EG Profile
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That is very possible. I don't think the drawing with the problem was started in an earlier version --- but with cut+paste, etc., you never know what strange things can get carried over from DWG to DWG....
R.K. McSwain
