• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    EG Profile
    321 Views, 17 Replies
    05-06-2010 01:01 PM
    I need to extend the existing ground profile. I previously had stopped the profile at 25+00 as shown in the attached. However, I need to add on another 100' to 26+00. I can only view info in the Profile Properties. I can't change the end station.
    How do I get it to extend?
    Thanks.
    Please use plain text.
    Valued Mentor
    Re: EG Profile
    05-06-2010 01:03 PM in reply to: bgriffin291
    Select Profile View, Right-click, choose Profile View Properties, then the Stations tab.
    HTH
    AWood
    *wfb
    Re: EG Profile
    05-06-2010 01:08 PM in reply to: bgriffin291
    First thing. Are you adding 100' to 25+00 or 26+00?
    1. Not sure in your "picture", why is the existing ground missing from Sta
    25+00 to 26+00?
    2. You can always use the line command and draw it.
    3. Turn on your triangles and make sure you have a surface where your
    alignment crosses since it should be showing in your "picture" if that is
    the case.
    Bill
    wrote in message news:6387192@discussion.autodesk.com...
    Thanks.
    Valued Contributor
    Re: EG Profile
    That doesn't extend the actual profile itself, only the profile view, i.e. gridlines, etc.
    I need the surface profile to be extened.
    Valued Contributor
    Re: EG Profile
    05-06-2010 01:13 PM in reply to: bgriffin291
    When I originally created the surface profile I stopped it at 25+00. The surface continues to 46+00, I just didn't need all that extra profile. I'm only designing 1000' of road.
    You cannot modify an EG profile using the layout tools either. I believe that because it is surface dependent using the line command is not an option.
    *Jeff Mishler
    Re: EG Profile
    05-06-2010 01:16 PM in reply to: bgriffin291
    Create a new surface profile from 25+00 to 26+00
    "bgriffin291" wrote in message news:6387200@discussion.autodesk.com...
    > option.
    *Matt Kolberg
    Re: EG Profile
    05-06-2010 01:44 PM in reply to: bgriffin291
    If you extend your alignment your EG profile will also extend.
    Matt Kolberg
    Global CADD Systems - A division of Cansel
    "bgriffin291" wrote in message news:6387197@discussion.autodesk.com...
    > gridlines, etc.
    Valued Mentor
    Re: EG Profile
    05-06-2010 05:04 PM in reply to: bgriffin291
    As an earlier poster noted, extending the alignment will automatically add the necessary EG profile to your profile view.
    *wfb
    Re: EG Profile
    05-06-2010 05:34 PM in reply to: bgriffin291
    To further expand on my item 3. in my earlier post. You may have a "hole"
    or no existing ground in your Surface along this alignment..
    Bill
    "Matt Kolberg" wrote in message
    news:6387214@discussion.autodesk.com...
    Matt Kolberg
    > gridlines, etc.
    *John Mayo
    Re: EG Profile
    05-06-2010 05:36 PM in reply to: bgriffin291
    If you extend the alignment and the profile view gets larger without the
    surface profile getting larger then you are either missing surface data
    under the alignment or the profile has lost it's link to the surface. Add
    data or resample the profile.
    John
