• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    ECW image shifting within paper space
    121 Views, 3 Replies
    12-02-2012 08:24 PM
    Problem: ECW image shifting within paperspace layout. Problem only with viewports which have been twisted.
    Computer:
    Windows 7 64bit
    32gig ram
    Quadro 2000 (on the supported list)
    Using Civil3d 2012
    Have tried recovering... moving the geometry is not an option.
    Have also tried toggling "Projection" on and off as suggested in other threads
    This seems to have been a long standing issue and its surprising there yet seems to be a fix
    Have made the same post in an AutoCAD 2011 as a reply to a board on the same issue. Link: http://forums.autodesk.com/t5/AutoCAD-2011/Image-shifting-in-Paper-Space-quot-Autocad-2011-quot/m-p/...
    Please use plain text.
    Valued Mentor
    Re: ECW image shifting within paper space
    12-03-2012 04:41 AM in reply to: jagreve
    Try switching the insertion method (Map Insert vs.. FDO attach). There is an outside chance that it might help. Otherwise, open a support request. You will inevitably get the official "known issue" response, but if there are enough of them on the pile they might eventually fix it.
    *Pro
    12-03-2012 05:11 AM in reply to: jagreve
    I've seen the image shifting when zooming in and out before.    As long as it plots the same way every time it's only been a annoyance not a problem.   It would be nice if they fixed it, but it's not high on my priority list.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Mentor
    12-03-2012 05:17 AM in reply to: dgordon
    Therein lies the problem - Sometimes it looks fine, but it always plots incorrectly Kirk Noonan Carter Associates, Inc.P (772) 562-4191 F (772) 562-7180
