• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Dynamic Scale Bar Question..
    706 Views, 4 Replies
    10-03-2012 06:50 PM
    I've used the search key and found multiple topics on scale bars but nothing that answered my question directly.
    How do I insert a dynamic scale bar?
    I'm trying to insert a scale bar into a paper space (I use layout wizard and make a layout). Then once I'm in the layout that I've created I see a button that says Scale Bar > and I have several to choose from; cool. I select the one I want to put in the drawing, and command bar asks me "Select viewport" ?? How do I select 'viewport'? Everywhere I click, it says 'Nothing selected'. I want it in there at 1:250 (the scale of my model space drawing, and the scale of the 'viewport' that I selected during the layoutwizard process.
    Would really appreciate any help with this.
    I also tried inserting one of the sample scale bar blocks (which are at 1:1 scale) and then scaled it up to 250, but it looks way to small for my drawing.
    Please use plain text.
    Distinguished Mentor
    Re: Dynamic Scale Bar Question..
    10-03-2012 09:03 PM in reply to: uwotmate
    You are doing everything I do to get the scale bars.
    Click the Scale Bar drop down
    Select a scale bar to use
    Click on the border of a viewport
    A dialogue comes up to enter the scale, label, divisions
    Click OK button
    Pick Point to insert the scale bar
    I have tried it with a rectangular viewport and a polygonal viewport, viewports locked and unlocked, also with the current layer off and locked, and it still works alright, although with the layer locked, you don't get the scale bar after you pick it's insert point.
    Turning the viewport layer off or freezing it makes it not visible so you can't pick it anyway.
    Sorry, but I could not find a way to get it not to work.
    If this fixed your issue, click on "Accept as Solution"
    Andrew Puller
    Maitland, NSW, Australia
    Windows 7 Enterprise 64bit
    Intel core i7 2600 @ 3.40 GHz with 16GB Ram
    Civil 3d 2013 64bit
    AllenJessup
    10-04-2012 05:11 AM in reply to: uwotmate
    You probably need to select the entity representing the outline of the viewport. That's the viewport object itself. You need to be in paperspace and the layer that the viewport was created in needs to be on, thawed and possibly unlocked. I don't use the layoutwizard of dynamic scalebars. So this is just extrapolation from other instances where you have to select a viewport.
    Allen
    01-11-2013 04:31 PM in reply to: andrewpuller3811
    Can I ask you what version of CAD you are using? I'm using CAD Civil3D 2012 and I can't find the "Scale Bar" drop down menu. I've tried typing it in the command line but that brought up nothing.
    AUTOCAD Civil 3D 2013
    Windows 7
    Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
    Installed Memory (RAM): 12.0GB
    System Type: 64-bit
    Erika
    neilyj
    01-12-2013 12:28 AM in reply to: uwotmate
    i think it first appeared in 2013
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
