• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Westhills
    Drop down menus in dialog boxes appear blank and cursor doesn't echo
    1614 Views, 38 Replies
    01-18-2011 11:07 AM
    In dialog boxes the drop down menus appear blank until I drag the mouse over it then the contents appear as I drag the mouse across. Also the cursor doesn't echo back (flash). I have tried updating drivers to no avail.
    Running Civil 3D 2011 with all updates.
    Windows 7 64 bit
    16 gig ram
    Quadra fx 1800
    Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
    I have attached a couple images to illustrate.
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Dual 24 Phillips screens
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: Drop down menus in dialog boxes appear blank and cursor doesn't echo
    01-18-2011 11:42 AM in reply to: Westhills
    My first guess is that your graphic card may need an upgrade.Try following before that:
    1. Check if you get the same behavior on other drawings
    2. Type 3DCONFIG and go to Manula Tune, toggle "Enable Hardware Acceleration", Apply
    3. If you et the same issue on both occasions then I would see if upgrading video driver helps. Just an idea.
    Good luck.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    Westhills
    01-18-2011 11:47 AM in reply to: AlmasSuljevic
    Thanks for the input. Your suggestions had already been looked at. Problem persists.
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Product Support
    AlmasSuljevic
    01-18-2011 12:09 PM in reply to: Westhills
    Can you post your drawing? I can try to open it on my machine to see if it's drawing specific.
    Almas Suljevic
    Autodesk, Inc.
    Westhills
    01-24-2011 10:07 AM in reply to: AlmasSuljevic
    Due to confidentialy reasons I cannot post the drawing. However I can confirm this is not Drawing related.
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Employee
    hgohel
    01-24-2011 12:38 PM in reply to: Westhills
    Which driver version do you have installed?  Check this list for a list of supported driver versions for the Quadro FX1800 with C3D 2011 on Win7 x64.
    Can you confirm that you have Update 1 for Civil 3D 2011 installed?
    Himanshu Gohel
    Autodesk, Inc
    Westhills
    01-24-2011 12:53 PM in reply to: Westhills
    Quadro fx 1800
    driver 266.45
    C3D has all updates.
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Employee
    hgohel
    01-24-2011 01:08 PM in reply to: Westhills
    You can try turning off hardware acceleration from within C3D/AutoCAD using the 3DCONFIG command -  restart C3D to make sure the settings are in effect.  Check whether your problem is resolved.
    From the snapshots you posted, you have a "desktop manager" software that might be affecting display of windows?  If so, you might try disabling that temprorarily to see if that helps.
    If not resolved, you may want to downgrade your graphics driver to one that is in the supported list - the one that you have installed isn't listed as supported/certified as of today.
    Himanshu Gohel
    Autodesk, Inc
    Westhills
    01-24-2011 01:56 PM in reply to: Westhills
    Tried reverting to this approved driver: 8.17.0012.6570. Did not change anything. Also tried running without hardware acceleration,. no change.
    Win 7 64bit
    16 Gigs Ram
    Intel i7 870
    Quadro fx1800
    C3D 2011/2012
    ASUS Custom
    Employee
    hgohel
    01-24-2011 02:04 PM in reply to: Westhills
    Great!  That rules out a lot of what C3D/AutoCAD depends on for proper display.  Let us know the results after you disable the display manager software that seems to be installed on your system (referring to the extra button with <-> on the windows in your snapshots).
    Himanshu Gohel
    Autodesk, Inc
