• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    jfengineering
    Accepted Solution
    Drawings zooms out on open
    300 Views, 22 Replies
    06-26-2012 08:51 AM
    I'm running 2013 C3D and have a quirk that my drawings zoom out when I first open the file.  I'm not even sure what they are zooming out to as it is not 'Extents'.  I had the same issue in 2012 but I thought I would see if anyone has figured this out.
    Thanks!
    JF Engineering, PLLC
    Windows 7 Pro, 64 Bit
    AMD Athlon II X4 645, 3.10 GHz
    8 GB RAM
    2x HP2311x Monitors
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Drawings zooms out on open
    06-26-2012 09:02 AM in reply to: jfengineering
    perhaps someone added a line in your acaddoc.lsp file?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    jfengineering
    06-26-2012 09:33 AM in reply to: Joe-Bouza
    I am an individual user and I've never even heard of that .lsp routine.  What does it do?
    8 GB RAM
    2x HP2311x Monitors
    jfengineering
    06-26-2012 09:51 AM in reply to: jfengineering
    *Update*
    I think this may actually be a bug.  I've figured out that this also happens when you change tabs between paper space and model space..  The view isn't zooming out, but rather it is going to the incorrect location.  I have a DView twist set, and my UCS set to view.  Under these conditions the opening view will go to the location the window would be if it did not have the Twist set.  If I change my UCS to World and switch between tabs it works without a problem.
    Where's my can of Raid?
    8 GB RAM
    2x HP2311x Monitors
    *Expert Elite*
    AllenJessup
    06-26-2012 10:21 AM in reply to: jfengineering
    One of the many reasons to stay away from any UCS in Civil 3D. I was always told by our reseller and trainers to avoid the USC and only use DView Twist.
    Allen
    jfengineering
    06-26-2012 10:23 AM in reply to: AllenJessup
    Thanks.   How do you get text / labels to be horizontal then?  Labels in paperspace?
    8 GB RAM
    2x HP2311x Monitors
    *Expert Elite*
    AllenJessup
    06-26-2012 10:47 AM in reply to: jfengineering
    For those that aren't Civil labels or notes I use Mtext and either select the R(otate) option or use the attached lisp that automatically grabs the Viewtwist. Ofcourse there is the TORIENT command if you have to align it after the fact.
    We don't do any (almost) labeling in Paperspace. Just viewport and titleblock.
    Allen
    *Expert Elite*
    Joe-Bouza
    06-26-2012 02:08 PM in reply to: jfengineering
    Is it possible that the system variable UCSFOLLOW id set to something other than 0?
    For the OP The ACADDOC.lsp file can be used to automatically load other lisp files and issue commands at startup
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    jfengineering
    06-26-2012 02:22 PM in reply to: Joe-Bouza
    UCSFOLLOW is set to 0
    8 GB RAM
    2x HP2311x Monitors
    *Expert Elite*
    AllenJessup
    06-27-2012 05:08 AM in reply to: jfengineering
    If you examine your command line history does it give you any clue?
    Allen
