AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Drawing Units Stuck on Architectu ral
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have an old dwg that I used to add new data to. I also inserted a block produced by Revit to get a building elevation. I am not sure when or how it happend, but my drawing scale units are stuck on arch. I am talking about the bottom right hand corner of the screen on the status bar where there is the spot to set drawing scale. When I open by clikcing the arrow all the scales are in architectural units. I can add a custom scale of 1"=100', but it does not otherwise appear in the list. I wasn't going to wrry about it, but when I layout a plan/pro series they do not seem to be scaling correctly (and I cannot find a place to specify what scale I want the views to be at). UNITS, -DWGUNITS & -AECDWGUNITS don't fix it, they are all set to decimal, etc. Using the seetings tab to change the drawing settings, everything is set to feet, there is no place to specify arch units, the 100 scale drawing is shown as a custom scale.
This is C3D release 2012, on a 64bit Win7 Pro machine, everything is up to date.
Does anyone know where I can change the units for the drawing scale?
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
Re: Drawing Units Stuck on Architectu ral
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See this post for a LISP routine that will export the scale list from one drawing and import into another:
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP
or this post that describes a way to do it with cut and paste:
http://forums.autodesk.com/t5/AutoCAD-2011/Import-
and you might want to look at Heidi Hewitt's blog post here:
http://heidihewett.blogs.com/my_weblog/2010/07/sca
Tim
Delta Engineering Systems
Redding, CA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
thanks Tim,
Not sure exactly what is going on, but I can get additional scales into the dwg using one of those methods.
David Renaud, RLS
