• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Dragged State Label Style issue of line between text not flipping
    779 Views, 8 Replies
    03-27-2012 02:26 PM
    I'm having trouble getting my label style to flip when in dragged state.  If I drag it off to the right, the text and line show up just fine, but if I drag to the left, the TC and FS head that way, but the line in between stays put.  Any help would be appreciated.  Please see picture attached.  Thanks so much!
    I've added some screen shots showing my settings as well.  Thanks!
    Please use plain text.
    Valued Mentor
    Re: Dragged State Label Style issue of line between text not flipping
    03-27-2012 06:10 PM in reply to: inquired619
    Flip anchors (maybe?) would need style settings to be sure.
    Active Member
    03-28-2012 06:21 AM in reply to: inquired619
    I have the text style settings attached to my initial post, but here is the line style setting within the composer...
    03-28-2012 06:28 AM in reply to: inquired619
    Change your display in Dragged State to "Stacked text".
    Bill
    Active Member
    03-28-2012 06:33 AM in reply to: wfberry
    Thanks Bill, but when I switch to Stacked Text, it yields the result in the picture attached.  Is there a way to get the line to go all the way in between the text (extend out)?
    03-29-2012 08:12 AM in reply to: inquired619
    Dragged labels using 'as composed' are not aware of the leader direction.  You will need a second style composed for dragging to the left.
    David Zavislan, P.E. | CAD Manager / Associate | NV5 | www.nv5.com
    Active Member
    03-29-2012 08:29 AM in reply to: david.zavislan
    How would I change the leader direction in a separate style?
    03-30-2012 09:00 AM in reply to: inquired619
    Edit the line component of the 'left' label style so that it goes to the left.  Change the the justification of the two text components to be left justified.
    When the label is dragged the leader and leader tail will automatically change between left and right.  I highlighted this in the following image, from your original post.  The red lines indicate the leader and tail and the green lines highlight the line component from the label style.
    Active Member
    03-30-2012 09:23 AM in reply to: david.zavislan
    Thanks David!!
