AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Do not show Point Number in table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a table of Wind Turbine coordinates but I don't want to show the point number - is this possible dynamically??
The only alternatives I've come up with are to use a wipeout but then the heading is off centre or to just explode and manipulate as CAD entities, neither of which are ideal
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
Re: Do not show Point Number in table
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Edit the table style. To get the first column to show something other than the point #, copy/paste the contents from the second column into the first overwriting the PointNumber value, then delet the second column.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is a workaround... you can actually go into edit your table style and copy/paste a different column value into the first column in lieu of the point number. Strange to have to do this to bypass, but I believe they didn't wan't you to ditch your point number![]()
Tyler H. Johnson
Civil3d 2013
Dell Precision T3500
Intel Xeon
24GB Ram
64Bit Win7 Pro
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the replies guys - that did the trick admirably![]()
...although you can't help feeling it would be easier to have a radio button/tick box to achieve this
