• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    bpoleuca
    Distance between existing and design aligment in CSS
    104 Views, 2 Replies
    10-30-2012 07:10 AM
    I want to ask if somebody know a trick to make automatic a dimension line for the distance between the existing alignment of a road and the design alignment.
    This dimension line I want to be in the cross sections.
    I make a project with a widening road and I have to show the diference between the old and the new alignment.
    Please use plain text.
    *Expert Elite*
    Re: Distance between existing and design aligment in CSS
    10-30-2012 11:48 AM in reply to: bpoleuca
    You could add a LinkWidthandSlope subassembly to your Assembly. Be sure to give it a unique Point Code and I would set Omit Link to Yes.
    In the Corridor Properties, set the old alignment as the target for this new subassy.
    In your Code Set Style, for the unique Point Code, create a label that reads the offset of the new point.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Contributor
    bpoleuca
    10-30-2012 11:29 PM in reply to: bpoleuca
    I will try.
