AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Dissappear ing & re-appeari ng contour style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have created a TIN surface from polyline contour data in Civil3D 2013. My file shows shows that the surface is present both in the Prospector and when I float over the surface and will preview. I assigned a style to the surface, which for my uses is displaying minors at 1' and majors at 10'. My problem is that the contours only display sometimes. That is to say, SOMETIMES I open the file and I can see the surface contours and other times it simply will not display them. There has been NO change to the layer (on, visible and not frozen) nor to the style (not assigned as not showing or any different color) between current and the time I used the file last. Occasionally, when I restart my machine, the contours will display for a few hours worth of work, but when I return the next day, or after a hang, restart my machine again, the contours simply will not show. If I add "show triangles" in the style definition, the triangels will show every time, but not the contours. This is SO frustrating.
In an effort to find some remedy an engineer firend suggested I changed my RAM from 2- 4GB DIMMs to 2- 8GB DIMMS giving me a total of 16GB of RAM, which I did, but it doesn't seem to have made any appreciable difference in performance and the contours still don't show. Does ANYONE have any ideas about why this may be occuring?
Thanks in advance
Civil3D 2013
MacBookPro 17 - 2.4GHz Intel QuadCore i7 (Late 2011 build)
Microsoft Windows 7 64bit
350GB Bootcamp volume
Re: Dissappear ing & re-appeari ng contour style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you have level of detail switched on (under view ribbon I think)?
(No connection with Autodesk other than using the products in the world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This sounds like Level of Detail is toggled ON. Try toggling it off.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hey! I didn't know about that... That seems to have worked. I'll have to see if it sticks.
THANK YOU!
Civil3D 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just had the same problem and that seem to be the fix!! Thanks!
Does turning off your level of detail just affect .tin surfaces?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think so - see http://beingcivil.typepad.com/my_weblog/2011/05/au
Re: Disappeari ng & re-appeari ng contour style
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks. I have been beating my head against the wall with this problem. I toggles off level of detail and it solved the problem right away.
Dale
