• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    Dissappearing & re-appearing contour style
    705 Views, 6 Replies
    09-28-2012 12:10 PM
    I have created a TIN surface from polyline contour data in Civil3D 2013. My file shows shows that the surface is present both in the Prospector and when I float over the surface and will preview. I assigned a style to the surface, which for my uses is displaying minors at 1' and majors at 10'. My problem is that the contours only display sometimes. That is to say, SOMETIMES I open the file and I can see the surface contours and other times it simply will not display them. There has been NO change to the layer (on, visible and not frozen) nor to the style (not assigned as not showing or any different color) between current and the time I used the file last. Occasionally, when I restart my machine, the contours will display for a few hours worth of work, but when I return the next day, or after a hang, restart my machine again, the contours simply will not show. If I add "show triangles" in the style definition, the triangels will show every time, but not the contours. This is SO frustrating.
    In an effort to find some remedy an engineer firend suggested I changed my RAM from 2- 4GB DIMMs to 2- 8GB DIMMS giving me a total of 16GB of RAM, which I did, but it doesn't seem to have made any appreciable difference in performance and the contours still don't show. Does ANYONE have any ideas about why this may be occuring?
    Thanks in advance
    Darin Kirschner
    Civil3D 2013
    MacBookPro 17 - 2.4GHz Intel QuadCore i7 (Late 2011 build)
    Microsoft Windows 7 64bit
    350GB Bootcamp volume
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Dissappearing & re-appearing contour style
    09-28-2012 12:12 PM in reply to: dkdzyn
    Do you have level of detail switched on (under view ribbon I think)?
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    09-28-2012 12:14 PM in reply to: dkdzyn
    This sounds like Level of Detail is toggled ON. Try toggling it off.
    Member
    09-28-2012 12:15 PM in reply to: neilyj
    Hey! I didn't know about that... That seems to have worked. I'll have to see if it sticks.
    THANK YOU!
    Darin Kirschner
    Civil3D 2013
    Active Contributor
    10-01-2012 09:31 AM in reply to: dkdzyn
    I just had the same problem and that seem to be the fix!! Thanks!
    Does turning off your level of detail just affect .tin surfaces?
    *Expert Elite*
    neilyj
    10-01-2012 11:25 AM in reply to: jeremy.2012
    I think so - see http://beingcivil.typepad.com/my_weblog/2011/05/autocad-civil-3d-2012-preview-surface-level-of-detai...
    neilyj
    New Member
    mdbutikofer
    Re: Disappearing & re-appearing contour style
    01-22-2013 11:53 AM in reply to: Jeff_M
    Thanks.  I have been beating my head against the wall with this problem.  I toggles off level of detail and it solved the problem right away.
    Dale
