Solved by AlmasSuljevic. Go to Solution.
Despite having the tooltips on, the tootip display does not appear when hovering over a surface. Any ideas on what the problem could be? I'm using C3d 2011
Hi Ryan,
If you have checked all these places (see link below)
http://www.civil3d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/
then let us know if you have Raster Design loaded and do other files get the same issue.
Thanks Almas
These options were all checked but when I unchecked and checked all of them again, my surface tooltips are back.
Just a glitch I guess.
Thanks again
Ryan
@AlmasSuljevic wrote:Hi Ryan,
We are running Raster Design and still have this issue in 2011. Any fix yet?
I think you can run Civil 3D with plain Civil 3D icon (without loading Raster Design). You may also see if you can unload Raster Design CUI (CUILOAD command).
The link that is being provided for www.civil3d.com always takes me to the main Autodesk page for Civil 3D. Not sure what's happening, but I can't get to a website with www.civil3d.com as the URL.
Try "civil4d" : http://www.civil4d.com/2007/03/who-killed-my-tooltips-four-usual-suspects/
@Almas: That fixed the link. Thanks!
I have Raster Design installed, yet when I open Civil 3D (not using the Raster Design shortcut) I still get the ribbon tab for Raster Tools. Raster Design isn't really loaded, yet the ribbon shows it and almost after every command the ribbon changes to the Raster Tools tab. Extremely annoying considering I rarely use Raster Design and the fact that I didn't explicitly open Raster Design.
Does Raster Design change the profile and/or shortcut for Civil 3D?
Just use the CuiUnload command to unload Raster Desigh and you will be good to go. If you need it later, re-load the cui.
Bill
Hi Almas, what the deal with raster design? Are there known issues? I have not been able to load jp2 aerials throght the fdo connection, but they come in with raster. is there a bug or fix ?
Your Name
Your Name
There was an issue with tooltips not displaying obejct information if RD is loaded. I don't remember anything about not being able to import jp2 files. One thing I do remember though is that JP2 import could bail out if there is no geo-reference on the file. Do you have Raster Object Enabler installed for 2011? http://usa.autodesk.com/getdoc/id=DL15201709
